Control Panel
I've just had to go back to factory settings and can no longer find Control Panel. In the past I right clicked Start and it was included in the list of options, but not now. How can I get it on my desktop or task bar
Wich version of Windows are you using ?
Right-click on Windows start and select « execute », then in the new dialog box, type « winver », and it will tell you wich version you're using.
If it's 1703, it's normal, Microsoft removed it from that menu.
Bye ;) JAY B.
Windows Key+S, type Control in the search dialog box. It should display the control panel icon, right click and pin to start menu or task bar. I have it pinned to task bar.
