- Jul 6, 2017
HP g-7, 8gb memory, W10 Home 64 bit Version 1703 Build 15063.413
After the 1703 update, I can bring up the control panel but all the features are INOP.
Even the minimize button is inop. It acts like a stuck screen and then "blinks" back to the desk top when you try to select a feature.
I did run a check of system files with no errors.
I did restore from a back up and re-installed 1703.
No help.
ANY ideas.
On another note, after the update, disk usage went to 100% and stayed there.
I turned indexing of on C: and that has returned to normal.
No help.
ANY ideas.
