Connection
Every morning when i switch on laptop and error occurs"failed to connect to a windows "
How do i get rid of this error
First, right click on the start button and select command prompt(admin)
TYpe at the prompt copy and paste sfc /scannow
This will take a little while. When it is complete copy and paste netsh winsock reset
Reboot the computer and see if the problem has gone
Hi there tried it initially worked well for 2 days and now everyday i have to do the same and battle to open my google chrome page.Windows 10 seerms to be a huge hassle
Hi Peter its the same for all of us no one is exempt from this issue. I strongly advise you to deactivate win 10 updates and change the default settings for privacy at the same time. Win 10 will ultimately break Microsoft, after we cannot ALL cant be wrong.
LOL. I.m exempt.
Peter.
Click the start button and Settings. Then Network and internet. Then, at the lower part of the page,
"Change Adapter Options"
Right click the adapter and select "properties."
Scroll down the list to "internet protocol version 6 (TCP/IPv6)
Select, again, properties.
Ensure you have both items set to obtain the addresses automatically.
It should be set as such by default, but third party programs can sometimes change this.
