I connect two PCs using crossover Ethernet cable, PC A is running Win 10, PC B is running Win 7. For some reason PC B is able to connect to PC A with no problems. PC A does see PC B in the network window, but none of the shared folders from PC B are showing up. I can open a Command prompt on PC A and ping the IP address of PC B and have no troubles getting a response. Ive tried turning off Windows Firewall on both PCs and still can't see PC B from PC A.
Found this as a possible solution
Any suggestions????
- Open Control Panel (by clicking on the Start button and typing in Control Panel, then click the App).
- I use Classic View, in which case click on "Programs ansd Settings". If you use the standard view, I'm afraid you need to find it yourself. Fairly easy.
- In the left panel, click on "Turn Windows features on or off".
- If the Security dialog box appears asking for your OK, give it the OK.
- The "Windows Features" dialog box appears.
- Scroll down to "SMB 1.0/CIFS File Sharing Support" and tick the box. This installs the Samba support.
Any suggestions????
