Can not uninstall audio driver
I have two identical drivers on my audio device. One says ok the other gives error 10. I un install the one with error but as soon as I restart it is reinstalled with same error. Sound does not work. Below are the two drivers the difference is in GENERAL>Locathion one says 2 the other 3
Name High Definition Audio Device
Manufacturer Microsoft
Status OK
PNP Device ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0889&SUBSYS_1458A022&REV_1000\4&35A89E12&1&0201
Driver c:\windows\system32\drivers\hdaudio.sys (10.0.10586.589, 395.00 KB (404,480 bytes), 9/17/2016 8:05 AM)
Status Error
PNP Device ID HDAUDIO\FUNC_01&VEN_8086&DEV_2804&SUBSYS_80860101&REV_1000\4&35A89E12&1&0301
I have tried various suggestions in the driver forum but could not find a similar one.
Hi Mansur,
Welcome to the Forum.
Both of those files ought to be in different locations.
  • C:\Windows\System32\HdAudio.sys
  • C:\Windows\System32\DriveStore\FileRepository\HdAudio.sys
They are the same file and size.
The reason you cannot uninstall the file is because its a System file owned by NT Authority\TrustedInstaller
You won't have privileges to uninstall that until you take ownership of the file first.
Why are you trying to uninstall it though?
You'd be better off opening an elevated command prompt (Command Prompt (Admin), and running System File Checker command: SFC /SCANNOW and allow Windows a chance to find error and repair.
  • Right-click on Start
  • Left-click on Command Prompt (Admin)
  • When the User Account Control appears click Yes
  • In the Administrator: Command Prompt window type SFC /SCANNOW then press Enter key
    This scan can take several minutes (DO NOT turn of computer while scanning!)
