SOLVED Can not "right click" on desktop.
I have a HP laptop. It has Windows 10.
I now wish to enlarge the icons. Right clicking on the desk top should open a window where this is possible.
But when I right click the desk top I get a "wait" symbol. This continues forever.
I need to know how to enlarge the desktop icons in some other manner, or how to fix the "forever" wait when I right click.
Thanks for reading.
jrj
Yes, the problem I had was solved. I did write the solution but screwed up when I trued to post it. My apology.
I have a HP laptop This solution worked for me. I hope it works for you.
JRJ
1. Right click Start
2. Select Device Manager
3.Select Display Adapters
4.Select Intel Graphics
5. Delete it
6. Restart computer.
Good feedback. When "Unsolvable" device driver problems occur, your solution often does solve it. Remove the old garbage and start again!- particularly if graphic problems are indicated.
