I am not if it is a hardware issue. But before I did the recovery, there was a message popped up on the screen said "Recovery. Your computer couldn't turn off properly. The operating system couldn't be loaded because a critical system driver is missing or corrupted. windows\system32\drivers\vmbus.sys. Error code:Oxc0000098. You'll need to use recovery tools."
I did booted from the recovery drive. The recovery process went to 30% then I got a Bsod. It restarted, went to 14%, then another Bsod. It just kept on repeating. So I took out the USB, tried to see if I could boot from hard drive. The computer said there was no bootable drive.
Bsod messages I received when using the USB were:
PNF list corrupt, System service exception, IRQL not less or equal.
