BSOD ntoskrnl.exe+142450 help!
I recently upgraded to Windows 10 and have since been getting BSOD when playing games, particularly League of Legends. I have run SDI tests to make sure all my drivers are up to date.
I have attached the minidump files.
Anyone have some ideas?
  • 030716-18640-01.zip
Looks like you may have an overclock condition that you might want to address to see if that might improve system stability.
ProcessorNameString = REG_SZ Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Update Status = REG_DWORD 6
VendorIdentifier = REG_SZ GenuineIntel
MSR8B = REG_QWORD 71000000000
Processor may be overclocked!
Expected Frequency: 3200
Actual Frequency: 4000
Overclock Ratio: 1.25
BaseBoardProduct = DX79SI
BaseBoardVersion = AAG28808-600
CPUID: "Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz"
MaxSpeed: 3200
CurrentSpeed: 4000
which would be somewhere in the neighborhood of 4.0 GHz
Yep, the first place to start troubleshooting is to turn off all overclocks. It shouldn't be an issue if your overclock was fine in the previous version of Windows, but I'd try that first. My advice would be a clean install whether that's the problem or not.
BugCheck 124, {0, ffffe001b2ec8028, be000000, 800400}
Probably caused by : GenuineIntel
Not good.
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffe001b2ec8028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000800400, Low order 32-bits of the MCi_STATUS value.
Really not good
FAILURE_BUCKET_ID: 0x124_GenuineIntel_PROCESSOR_MAE
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x124_genuineintel_processor_mae
I've literally tortured cpu's and never saw those errors. I agree, not good.
