SOLVED Bootable hard drive for W10 64 bit
I did clone with Easus and Macrium. Both delivered files to the target HD but HDwill not boot. How to make it bootable?
While I can't say for sure as I don't use either product, I have only two questions.....
Did you clone all the disk partitions when your performed the task?
Did you remove the source drive from the computer and re-attach the destination drive to SATA 0 on your computer (the SATA port that the original source drive was attached to)?
A third potential question might be...... What does your computer actually do after the cloning process is completely finished? Do you receive an error? IF so, what is that error?
Your question might be more readily addressed by the support forums for the particular product you are using
https://forum.macrium.com/Forum22.aspx
