audio through mic port
Hello all!
I'm not sure this is the right forum but I'm having toruble finding hownto exactly do this.
What I am wanting to do is play a recording of myself through the USB microphone port on windows. I do a telephone based job and basically want to play my greeting with that. I heard I can use virtual audio cable but I have not found how to use it.
Anyone have any ideas?
Growing up I learned that any speaker can be converted physically to a microphone, but I never heard of anyone trying to do the opposite.
I have no idea why anyone would want to do that.
I have no idea what the actual sound quality might be
AND
It would seem that if you have an audio file that you've created
It would seem easier to transfer that file to a device equipped with speakers (even a smart phone) and listen to it.
Having said all that, with a little research I found this
Which would seem to fit the bill.
Okay I will check it out.
The main reason is to not have to say my opening greeting on every caller I get.
The virtual audio cable is the best software there is to play audio through a mic port.
I could link you to a blog that tells you the way to play that audio through that app.
