You might be able to rescue your computer by enabling the normally hidden / disabled Administrator account and use that to possibly fix the password problem on your local user account.
You'll need to boot from the installation media. If you do not have the installation media on hand you can download the ISO from here
Choose Windows 10, the first item in the first drop down (not single language at the bottom)
Next choose your language and your bit version (32 or 64 bit to match your system architecture or in the case of an upgrade, to match your currently installed version of Windows).
That will provide an ISO that will upgrade, repair (or clean install) either or both Windows 10 Pro and Home.
Once you have downloaded the ISO you can use ImgBurn to burn it to a DVD
http://imgburn.com/index.php?act=download
OR
Rufus to burn it to a USB ThumbDrive
http://rufus.akeo.ie/
When you've managed to boot from the installation media you should be able to follow the example given in this article here.....
http://pureinfotech.com/2015/11/20/how-reset-windows-10-forgotten-password-regain-access-computer/
Once you can boot from the Administrator account, you should be able to fix your user account issue.
