My desktop PC is 4 1/2 yo Inspiron 3487 with Win 10 Pro.
Changed my USB Hub and now 4 out of 6 USB connections (on the rear of my CPU) do not work (IE when I plug in various USB 2 Flash Drives they do not register). Everything else seems to be working correctly (Internet, File Explorer, Dragon Naturally Speaking, etc.).
The same Flash Drives work correctly when plugged into the USB connections on the front of the CPU.
2 of the USB connections (on the rear) still work – both USB 2. I connected a USB 2 Hub and plugged in Flash Drives plus a Scanner and they all work correctly.
Did a Google search and found a Microsoft article describing the situation when a USB connection doesn't work. The workaround/correction is to disable the Root Hub in question and reboot – but the only thing that it did was to slow down the reboot.
Any other suggestions?
