Multiple Errors Causing Issues - Seeking Fix
I'm encountering several errors that are causing major issues on my PC:
I can't open any game that uses Easy Anti-Cheat; it closes immediately.
Upon booting, I receive the following errors:
"nvcontainer.exe - Application Error: The instructions at 0x00007FFA6634467A referenced memory at 0x0000000000000018. The memory could not be read."
"BlueStacksInstaller.exe - Bad Image: C:\Users\CMP\AppData\Local\Programs\bluestacks-services\ffmpeg.dll is either not designed to run on Windows or it contains an error."
I’ve tried running sfc /scannow as an admin, but it reports "Windows Resource Protection could not start the repair service." DISM /Online /Cleanup-Image /ScanHealth returns "The WOF driver encountered a corruption in the compressed file's Resource Table," and DISM /Online /Cleanup-Image /RestoreHealth gives the same error.
These errors persist even in safe mode. What else can I try to fix this issue besides a full, clean reinstall of Windows?
