- Aug 25, 2020
I was going to start using Edge browser till I encountered a few problems. I started to go through the privacy settings, although Edge say's it helps you to stop trackers, it also tracks your browsing too and save's it with no option of opt out, bit too much for me really. The other thing is, why do you have put up with agreeing to a cookie banner each time you open it?. And try as I might, no matter which search engine i chose, it reverted back to bing in private mode.
