- Apr 25, 2024
Hello, I am experiencing driver issues after replacing my CPU cooler. My CPU worked fine before, but it was running too hot under load. Now, when I try to use my GPU, the driver times out. The system worked for a week before the cooler swap, and then it ran for about 10 hours after the swap. However, while playing GTA V, I encountered a driver timeout error.
Here is the latest error from Device Manager: Device PCI\VEN_1002&DEV_73FF&SUBSYS_65051EAE&REV_C7\6&2c9ce418&0&00000019 had a problem starting.
Driver Name: oem15.inf
Class Guid: {4d36e968-e325-11ce-bfc1-08002be10318}
Service: amduw23g
Lower Filters:
Upper Filters:
Problem: 0x0
Problem Status: 0xC00000E5
How do I fix this? Is my CPU cooler pressing too hard on the CPU or maybe a software issue that can't be fixed?
Thanks for your help.
Service: amduw23g
Lower Filters:
Upper Filters:
Problem: 0x0
